Frequent Contributor II
IAP105 and IAP315 IDS settings
we have a customer that has a cluster of IAP-105's Now they decided to buy new IAPs to cover an extra zone. They bought IAP305.
Now there is no firmware available in 6.5 for IAP-105 apparently. So they need to create a seperate cluster for the new IAPs.
Offcourse with their IDS settings both clusters are seeing eachother as rogue and this is giving our customer some issues.
Is there a possibility to whitelist eachother in IDS?
Kind regards,
Thomas
Thomas
ACMX#370 ACCP
Re: IAP105 and IAP315 IDS settings
You should be able to mark the other system's APs on each as 'valid' or 'known interferer'
Jerrod Howard
I tried on my LAB IAP, but couldn't find the possibility; but I will look into it again.
Tnx!
Thomas
ACMX#370 ACCP
MVP
check http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-manually-re-classify-a-monitored-AP-in-Instant/ta-p/260755
Koen (ACMX #351 | ACDX #547 | ACCP)
tnx koen, exactly what I was looking for!
Thomas
ACMX#370 ACCP
