Contributor II
IAP205 History Help
im currently using Airwave Management Platform 8.2.5 with IAP-205's on version 6.4.4.8-4.2.4.9. Im looking for help on how i can print a report of all clients connected to a particular AP over a course of time regardless if those clients are still connected or not. is this possible?
Re: IAP205 History Help
You would create a new Client Session Report and adjust the dates to your liking.  Also you would need to adjust the Report Restrictions to filter on devices (access points).   In the device search filter, you would put the name of the IAP that you want to only see results for.  Save and Run.
Contributor II
Thanks cjoseph for the help.
