Frequent Contributor II
IAP275
Can I use only poe injector (802.3af) ? for supply power to IAP (on datasheet, maximum power consumption is 23 watt)
or use 2 ethernet port 10/100/1000base T. for supply power to ap (each port power budget is 15.4 watt)
Thank you
Re: IAP275
No.  Please see the installation guide here:  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=17323
Only a single 802.3at power source or AC is required:
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: IAP275
Note as well that the AP-27x family will ONLY accept POE on ENET0 interface. ENET1 will not receive POE.
Jerrod Howard
