IAP305 SSID won't showup
Hi.
I have bought IAP305 lately and started to setup.
First, I connected to my router with a cable.
In many docs I see, "instant" SSID should show up in my PC, which it doesn't currently.
I could access to console with both ssh and browser.(it aquires and IP address from router's DHCP server)
And I could see the default "instant" network configured in the web.
Is there anything I should do ? Or anything I've missed ?
If I create another Network with new SSID, it won't showup either.
Thank you guys in advance.
Re: IAP305 SSID won't showup
What version of Instant?
What regulatory domain?
 Thanks for the reply.
Will this do ?(How do I get the regulatory domain?)
# show about
Name :Aruba Operating System Software
Type :305
Build Time :2016-12-15 01:54:43 PST
Version :6.5.1.0-4.3.1.0_57768
Website :http://www.arubanetworks.com
Legal :(c) Copyright 2016 Hewlett Packard Enterprise Development LP.
Cloud Activation Key:
Are these new IAPs or used?
Did you try factory resetting it using the button?
It's new one.
I bought three of them, and tried the same thing in two which turned out to be the same result.
And also tried factory reset several times which turned out to also fail.
Is there anything I can provide ?
% show run
% show tech-support
Are you using DHCP?  If you setup a new SSID, the Instant SSID should disappear.
For uplink, I use  DHCP.
And for the Instant SSID, I didn't touch anything so it should be default.
If I setup new SSID, Instant SSID disappears, and new SSID appears.
But the problem is that I can't see it on my PC or on my smartphone.
(can't see both Instant and original SSID on PC/smartphone)
Which smartphone are you using?
I've tried
MacBookPro
iPhone5, iPhone6S, OnePlus2
Windows10
