IAP325 : modify the wifi range
Hi everybody!
First of all, i'm fairly new with aruba network and english is not my native language, so please, be kind!
For my new job, i've to add a Wi-Fi network to the building. My boss don't want that the network spreads too much outside the building. So, i'm looking for a solution to reduce the range of the AP. We use an Aruba IAP325 for the tests.
I tried to modify the settings in "RF/Advanced options/RADIO" and set those options:
  • 2.4GHZ --> Min 3. Max 12.
  •  5GHz --> Min 3. Max 12.
But it seems it doesn't change anything for the wifi range.
What am i missing ? Are there any options that could resolve my problem?
I hope i have explained my problem as clearly as possible.
Thank you!
Regards.
Re: IAP325 : modify the wifi range
Can you see what the transmit power on each band is for that AP on the dashboard?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Where can i find those informations?
I use the version 6.4.4.4-42.3.0-54225 if this can help...
Thank you for your fast answer btw.
The front page should list all of the access points and their current transmit power...
See the attached file, i only got those information on the dashboard.
EDIT : See also the txt file containing the command #show ap debug driver-config
Thank you.
