Frequent Contributor I
IDS Signature match and containment
We are using OS 6.1 and we need to auto-contain systems that emits signatures that matches our IDS signatures. I looked at the documentation for containment of signals/ signatures that matches a specific IDS signature but it does not say how and where is this configured. Please provide some guidance if you know. Thanks.
Re: IDS Signature match and containment
You can only detect signatures and report them.
This is a surprise to me. Thanks.
Contributor II
So we can´t contain a deauth attack?
Regards.
Trusted Contributor I
look at the last reply, you can do something if you use 6.4 and the client support 802.11w:
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Block-deauth-attack-with-Aruba-WIPS/td-p/165634
but in general deauth attack is a tricky attack to mitigate, you cant prevent a client from sending things into the air.
Contributor II
Ok, thanks.
