IOS/ Android Airgroup issues
  • 1.  IOS/ Android Airgroup issues
    Posted Jun 08, 2017 09:18 AM
    I'm in the process of configuring some simple Airgroup access on our dev mobility controller ( 6.5.2.0)
    Server devices - Apple TV3, Chromecast2 audio , Chromecast2 UD
    Clients - Android 7 tablet, IOS 10 iPhone
    Primary app Plex - audio and video streaming but also use BBC iPlayer and  Spotify
    2 SSIDs , airgroups-ipv6 and  airgroups-ipv6-psk performing WPA2-Enterprise and WPA2-PSK authentation. For -psk you also have to have client adress in a static ost list in clearpass and only devcs with specific DHCP signature are allowed on, else you get an access-reject sent.
    Both SSIDs place a device on  the same VLAN and IP address assignment via DHCP IP Pooling.
    On the mobility controller .....
    Authentication assigns a speific Airgroup Role with a policy of "allowall"
    Controller AirGroup services selected ... everything except remotemgmt and allowall
    Airgroup Global settings
    All enabled except AirGroup Active Wireless discovery
    Clarpass cluster set up as AirGroup CPPMserver
    Airgroup Domain defined a UoY
    Vlan table
    multiple  vlans defined but only two used for airgroups
    237 for wired devices with both ipv4 and an ipv6 IP address
    496 for wifi devices no ipv6 ip address assigned to controller
    All other vlans  disabled
    Controller Airgroup policy.
    For apple TV have user group defined as its a wired device doing dot1x
    An android device can see and 'cast to the Apple TV, and both audio and video chromecast devices
    An iOS device can only see and stream to the Apple TV
    iOS Google home app can see the Chromecast devics, no other app on the iOS device can even see the devices
    On a normal home network ... iOS can see and cast to ChromeCast devices
    Wired devics on 144.32.230
    Wwifi devices on 10.241.252.x
    show airgroup blocked-service-id  gives
    AirGroup Blocked Service IDs
    Origin Service ID #response-hits
    144.32.230.4 _rfb._tcp 386
    fe80::876:23f3:4776:2fbc _ssh._tcp 8401
    fe80::876:23f3:4776:2fbc _sftp-ssh._tcp 8401
    10.241.252.213 _teamviewer._tcp 257
    10.241.253.208 _esdevice._tcp 91
    10.241.252.53 urn:schemas-upnp-org:service:AVTransport:1 1320
    10.241.252.53 urn:schemas-upnp-org:service:ConnectionManager:1 1338
    10.241.252.53 urn:schemas-upnp-org:service:RenderingControl:1 1320
    10.241.252.53 urn:schemas-cyberlink-com:service:RemoteControl:1 18
    10.241.252.53 urn:schemas-cyberlink-com:service:SyncControl:1 18
    fe80::1c87:96fe:eb2b:1188 _atc._tcp 134
    10.241.253.4 _nvstream._tcp 12
    fe80::4ab:d0ac:b8a9:93af _eppc._tcp 74
    fe80::1864:25cb:406b:c5d4 _apple-lgremote._tcp 34
    fe80::1864:25cb:406b:c5d4 _osc._udp 43
    fe80::a6e4:b8ff:fe87:89a _tunnel._tcp 37
    fe80::a6e4:b8ff:fe87:89a _friendly._sub._bp2p._tcp 37
    fe80::a6e4:b8ff:fe87:89a _bp2p._tcp 82
    fe80::a6e4:b8ff:fe87:89a _invoke._sub._bp2p._tcp 36
    and more ......
    enabling "allowall" airgroup service makes no difference
    SSIDS have
    Broadcast/Multicast  DMO enabled
    Dro Broacast and unknown multicast  enabled
    Convert Broadcast ARP reqiests to unicast enabled
  • 2.  RE: IOS/ Android Airgroup issues
    Posted Jun 09, 2017 07:07 AM
    Also .... With the Google Home  app on my iOS device I can see all my chromecast devices and switch them . into guest mode or reset them ....just fine
    ... just can't see them . via IOS :-(
  • 3.  RE: IOS/ Android Airgroup issues
    Posted Jun 09, 2017 07:20 AM
    ...o.k. getting better .... the You tube app works on ChromeCast Video from iOS .... but bbc iplayer doesn't
    Looks like its more down to the apps on the iphone
  • 4.  RE: IOS/ Android Airgroup issues
    Posted Jun 09, 2017 07:33 AM
    Does beg the question though why iOS at home sees everything and it "just works"
  • 5.  RE: IOS/ Android Airgroup issues
    Posted Jun 09, 2017 08:43 AM
    You should turn off Airgroup and turn off broadcast filtering to emulate your home network.
  • 6.  RE: IOS/ Android Airgroup issues
    Posted Jun 10, 2017 05:13 PM
    But we can't do that in our production environmnt. Are their any details anywhere of what the diffeences are between "home" and "enterprise" Airgroup functionality?
    A
  • 7.  RE: IOS/ Android Airgroup issues
    Posted Jun 10, 2017 06:01 PM
    That is for testing to see if the problem is the infrastructure or the IOS device.
  • 8.  RE: IOS/ Android Airgroup issues
    Posted Aug 04, 2017 04:33 AM
    did you solve this Alex? We are seeing the same behaviour, we are on 6.5.3.1, the iphone can see the chromecast via the google Home app. But not able to cast to it via Apps.
    Android and Windows work perfect.
