Bus
Occasional Contributor I
IOS9 Fingerprint it's not working (370103060F77FC)
 After IOS update to version 9 (Iphone IOS9.xx) , controller can't separate vlan (Smartphone and Local PC),Please share new Fingerprint IOS9
Re: IOS9 Fingerprint it's not working (370103060F77FC)
If you enable DHCP debugging and then connect the device, you can grab the fingerprint from the debug logs.
Tim Cappalli | Aruba Security
