Regular Contributor II
IP Mobility question
Hi Forum,
I'm trying to setup IP mobility on a Master and 2 locals cluster of 7005 controller. I was reading the arubaOS user guide 6.4.2.x page 600 and has the step-by-step configurations which looks very simple(see the screen cap). The Master controller on the other hand does not show me the options on step 3 from the user guide. I have not done this before any any help is appreciated.
Re: IP Mobility question
That point should be for the 6.1. The 6.2 and above should have options only for the "Home agent" and "Description". Try adding only the Home Agent IP and Description. That should work.
Rajaguru Vincent
Rajaguru Vincent
OK so what vlan will be "mobile" then? The screen cap is from 6.4.2.x user guide! could be that it was left there by error?
[ Edited ]
If I'm not wrong, that should be an error. Let me share the screen shots from 6.1 and 6.4.
6.1:
6.4:
The VLAN information is not required now. See below link, that would help I guess.
http://community.arubanetworks.com/t5/Controller-Based-WLANs/ArubaOS-6-2-IP-Mobility/ta-p/182856
Rajaguru Vincent
Rajaguru Vincent
