IP sec tunnel issue between master and local controller
if the tunnel between the master and local controller drops due to master controller's unavailability , would that cause the ap which is present at the local controller's location not to join the local controller ?
i have taken some outputs from the local controller, because since master controller is not rechable .
if i can take console of the ap, what commands can we execute on it to check what is the reason of it not to join the local controller ?
(UNA_USWDCW1_WCNT1) #show switches
All Switches
IP Address     Name               Location          Type   Version        Status  Configuration State                Config Sync Time (sec)  Config ID
----------     ----               --------          ----   -------        ------  -------------------                ----------------------  ---------  UNA_USWDCW1_WCNT1  Building1.floor1  local  up      LAST SNAPSHOT(Master Unreachable)  0
UNA_USWDCW1_WCNT1) #show switchinfo
Hostname is UNA_USWDCW1_WCNT
IKE PSK: Aruba1122
Configuration unchanged since last save
No crash information available.
Reboot Cause: Power Failure.
(UNA_USWDCW1_WCNT1) #show crypto ipsec sa
% No active IPSEC SA
(UNA_USWDCW1_WCNT1) #show master-local stats
Missed -> HB Resp from Master
IP Address     HB Req      HB Resp     Cfg Terminate  Peer Reset  Total Missed  Last Sent Missed  Last Synced/Last Missed
----------     ------      -------     -------------  ----------  ------------  ----------------  -----------------------  0           0           0              3642        36420         36420             Pending/Fri Oct  6 09:08:59 2017
