IPSec over Mesh
I have an Aruba Controller (SW: 6.1.2.7) and I have to build up a Mesh. This mesh is secured by WPA. My problem ist that the customer does not trust WPA.
Is there a soulution to encapsulate the WPA-Traffic into an IPSec tunnel? I've readed about double-encryption but this is only a feature for RAPs.
Marco
Aruba
Re: IPSec over Mesh
Please note that Aruba OS MESH links are encrypted by WPA-2, not WPA.   A big difference... although neither is in danger of being practically breached at this point in time.
Keep in mind that the WPA-2 we use on mesh links utilizes AES encryption (circa 1990's) which is ~20 years newer than the typical encryption type used by VPN clients (3DES...circa 1970's).    aka.   one is actually much 'safer' when using AES... aka the Mesh link encryption than a VPN client if one takes a step back to consider the underlying technologies in use.
Hope that helps... ?
JF
Re: IPSec over Mesh
thanks for your answer. Yes WPA2 is secure, I believe that :-)
But the customer want's to have an IPSec-Tunnel in the WPA2-Tunnel because he dont trusts in WPA2.
Is there a possibility?
The solution should be
RAP ------> MESH-Point --------------------------------> Meshportal ---------->LAN------------> Aruba
In this sample the RAP will make an IPSec-Tunnel to the Controller. He uses the Mesh-Bridge so that ther is IPSec encapsulated in an WPA2.
Is this solution possible without the RAP (with only 2 APs)?
Marco
Re: IPSec over Mesh
mawe wrote:
Marco
Marco, is this a wireless or wired client that will be connecting to the mesh point?
Re: IPSec over Mesh
there will be a switch which is connected to the Mesh-Point via LAN. The Mesh-Point is a single-radio-AP so that there will be no wireless connectivity for clients.
Problem is that the customer dont wants to use VPN-Clients :-/
All things should be done by the Controller.
