Occasional Contributor I
IPTV Multicast Configuration on Controller 7200
Please Help.. I have an issue with the iptv streaming on aruba wireless, its working fine on the wired connection but when streaming over the wireless it isn't working any advice ? .. notice that we are using a full aruba products deployment (aruba switches , wireless controller , clearpass) and we are using aruba controller 7200 with ArubaOS 6.5.3.2
What is the required configurations for the multicast on each device ?
Frequent Contributor I
Re: IPTV Multicast Configuration on Controller 7200
Do you have IGMP snooping or proxy enabled on the controller/switch?
#AirheadsMobile
Yes i have enabled IGMP and IGMP Proxy
