Occasional Contributor I
IPv4/6 Dualstack and vlan-pooling - does it work?
I've started planning IPv6 addition to our IPv4 environment and would like to know experiences about that. The idea would be to use old vlans and IPv4 and IPv6 addresses as a mixed environment. No DHCP for IPv6 is deployed at this stage and the plan would be to use slaac.
I remember that vlan pooling didn't work with IPv6 in some stage? What's the situation nowdays?
Are there any other challenges regarding basic VLAN/IP operations when adding IPv6 to the picture?
Trusted Contributor I
Re: IPv4/6 Dualstack and vlan-pooling - does it work?
i recall this thread about ipv6 on aruba, you might request there to provide an update if it is available from the writer:
