Trusted Contributor I
Idle timeout should be driven by STM for MAC
i was going through some user debug logs and saw the following lines:
Sep  3 16:54:49  authmgr[2021]: <522246> <DBUG> |authmgr|  Idle timeout should be driven by STM for MAC aa:bb:cc:dd:ee:ff.
Sep  3 16:54:29  authmgr[2021]: <522247> <DBUG> |authmgr|  User idle timer removed for user with  MAC aa:bb:cc:dd:ee:ff.
is that normal? if the STM (what does it stand for?) drives the idle timeout, what is the idle time out then?
Re: Idle timeout should be driven by STM for MAC
These two log entries relate to how we handle users aging out of the system. STM stands for Station Management and it is a control plane process in Controllers and APs. Prior to 6.2, idle timeout was handled by a different process and after that it was handled by STM to improve scalability.
So there are two timers at play here:
  • Station timeout period which is a setting under “wlan ssid-profile <name>”. The default is 1000 seconds.
  • Idle timeout period is a setting under “aaa timer”. The default is 300 seconds.
In 6.4.1 we also have some aaa-profile timers to override the global aaa but let's put that aside for this discussion.
There are two predominate situations where these come into play.
Client sends a disassociate from an AP.
--> In this situation, once the client dis-associates, the user will age out according to the aaa idle timer.
Client doesn't send a disassociate but stops sending traffic (e.g. walks away)
--> In this situation, the client will age out according to the station timeout.
Now going to your specific log entries, these are typically seen during user creation. I suspect if we had the full log set, we would see a "Station UP" event preceding these messages. Is that the case?
Best regards,
