If configure 2 controllers to master and local, what info will not be sync ?
Hi, we have 2 controllers and want to configure them as master and local, besides layer 3 Ip address setting is different, any other info won't be sync from master controller? Please advise, thanks in advance.
Re: If configure 2 controllers to master and local, what info will not be sync ?
VLANs, syslog, NTP, local credentials, SNMP, etc
Tim Cappalli | Aruba Security
Thanks for reply.
How about server , server group, local DB (internalDB) ?
Take a look at this:
http://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/Adding_Local_Swit
ches.php
Thanks for reply.
But the page cannot be found
