If want to monitor controller port up/down by using NMS, do need to manually enable snmp trap ?
Hi, if we want to monitor the aruba controller interface up/down by using NMS, do we need to manually enable snmp trap on each interface configuration?  Please advise ,thanks.
Re: If want to monitor controller port up/down by using NMS, do need to manually enable snmp trap ?
By default wlsxPortUp and wlsxPortDown is enabled.
Type "show snmp trap-list | include Port" on the commandline.
