Implement STP in Aruba Controller
Hi Guys,
Actually we have 2 Aruba Controllers (3200 XM) AOS 6.3.1.8 and we need implement STP to connect 2 ports from the controller to the SW Core Cisco (6513).
What is the best way to implement STP?
Thanks in advanced.
Blanca Nieto
Re: Implement STP in Aruba Controller
Is this for redundancy (different Cisco switches) or to aggregate throughput  (same Cisco switch)?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Yes, is for redundancy, and we have 2 differents Cisco switches..
Thanks in advanced....
So it all depends on what kind of spanning tree you are deploying.  I searched for pvst+ in the knowledgebase and this is the first article:  http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-configure-PVST/ta-p/179474
