Implementation Guide to Master / Local redundancy
Hi, we have 2 x 3200xm controllers.  I have been through the design guides and seems the best option for redundancy is to configure as master / local in active standy.
What I could really do with is the configuration commands / guide to implement this.  I have found a guide which shows how to setup the VRRP but it doesn't show the steps for database sync.  I would prefer to follow a step by step guide if such a thing exists to ensure we get the configration right first time and don't miss any steps.  Can anyone advise on any step by step guides to setting this up?  As I said I already have the design guides so it's not that, I need the configuration commands.
thanks
Moderator
Re: Implementation Guide to Master / Local redundancy
There's no db sync in a Master-Local deployment.
What you have is a replication of most items of the configuration each time you save it.
Regards
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
There are several options for redundancy.  The best place to get the configs (IMHO) is here:
http://www.arubanetworks.com/vrd/CampusWNetworksVRD/wwhelp/wwhimpl/js/html/wwhelp.htm#href=Chap5_Redundancy.html
Thanks!
