Impossible to activate spectrum load balancing
Load balancing is totally desactivated on our infrastructure and i would like to implement it.
I read the load balancing "evolution" from "ap load balancing" to "spectrum load balancing".
I try to activate spectrum load balancing, without specific domain (ARM is active) on an ap group but when i check the "show ap active", it seems there is not the "L"... And clients are not load balanced !
On 2 neighbor AP, i have the 1st with 36 clients and the 2nd 2 clients.
I think i missed something :)
I used the user guide and the "managing and optimizing RF spectrum for Aruba WLANs".
Could you please explain me what i miss or which doc explain the load balancing implementation ?
Thanks.
Regards
Re: Impossible to activate spectrum load balancing
What AOS version do you have installed today ?
If you have 6.3 then SLB is part of the ClientMatch algorithm
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I'm in 6.3.1.2
So do i need to check the Client match parameters ?
YOu should be fine with the default values
Read this:
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/How-does-dynamic-load-balancing-works-with-client-match-on-Aruba-OS
Thank you
Victor Fabian
Ok perfect thanks.
Very bizarre that ap load balancing and spectrum load balancing are still available on the controlers...
By the way, when i look closely to "show ap arm client-match summary", there are very few devices load-balanced....
ClientMatch overrides it but if disable clientmatch then you need configure it manually which you probably don't want to do
Thank you
Victor Fabian
