Frequent Contributor II
Indoor as Outdoor
i want to use an indoor AP ( Ap93 ) in an out door area ,  area is small ( 5*6 Meters ) ....... is there any concerns ?  if i will geta box to protect AP from envirionmental issues ( water , air ....... )
Re: Indoor as Outdoor
If you have a box, it should be:
- Waterproof
- RF transparent
- Temperature controlled
- Resist changes in humidity
This is not an endorsement from Aruba, but a few customers I know have used Oberonwireless successfully:  www.oberonwireless.com
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi.
Good evening,
in Continues to cjoseph post.
-u may also consider use a an AP with external antennas +Cable+LAR+Outdoor antenna and use outdoor antenna.
-and then u don't need any box - deploy the AP inside an indoor/weather-proof environment (Building)
(i have an old deployment like this of AP-60 units!! In -24c environment !! . THE AP units are located above this big cold warehouse in a good weatherproof environment .And only antennas and cables are located in the rough environment.)
have a lovely week.
Me
