Occasional Contributor I
Initial setup for Aruba controller 620 and iap 105
Hi everyone.
I just get my aruba controller 620 and two iap 105. i did some research and reading on how to configure both devices so that it will appear in controller console, but no luck.
my setup
controller 620 connected to network 172.16.28.0/24
two of my iap 105 connected in the same network which is 172.16.28.0/24
DHCP given from my dhcp server in the same network as well.
Is there any step that i missed? if there is easy 101 initial setu guide, can someone point me to the right direction lol.
please let me know if you need any other information
Thanks in advance:smileyhappy:
Frequent Contributor II
Re: Initial setup for Aruba controller 620 and iap 105
ve you checked the AP installation tab in the webui?
Are the APs provisioned yet?
What does the AP boot log say? Does it discover its master?
-ACMX #352-
Remember to Kudo if a post helped you! || Problem Solved? Click "Accept as Solution" in a post!
Hi Nesvik,
I'll check it once i be back in office :-)
No AP was found
 Attached files areboth my iap webgui console and controller console.
