Installation guide for MSR 2000
Can anyone provide me configuration guide for MSR 2000.
Frequent Contributor II
Re: Installation guide for MSR 2000
you can find this and other usefoul docs under Aruba Documentation area
Software User & Reference Guides / AirMesh / MeshOS
for moderator:
i don't know if goes against forum terms of service to post Product Documentation that are under authenticated area
if so warn me and remove the link
Andrea Consadori
ACMP 5.0 and 6.3
Maybe Aruba needs to have it in the un-authenticated portion of the documentation section.....
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi, Thanks a lot for your reply....
