Instant 8.3.0.0 Mesh disabled
Hi! Im having problems setting up mesh in Instant 8.3.0.0. My setup works fine in 6.5.4.6, but upgrading to 8.3.0.0 gives me the "No mesh supported in current mode" when running Show ap mesh link. Running the same config, and downgrading to 6.5 fixes the issue.
I have looked in the user guide for 8.3.0.0. but i can't find any new settings required to enable mesh in 8.x software.
Anyone know what is up?
Re: Instant 8.3.0.0 Mesh disabled
What model access points are those?
IAP-225, IAP215 and IAP 303H are present in the cluster. IAP-215 is my current Mesh Point.
The IAP-303H does not support mesh, so that might be why you got that message.
That i did not know. Thank you.
I got that from the ArubaOS 8.3.0.0 release notes:
The other access points say that they support mesh.
