Regular Contributor II
Instant APs cannot be converted to Campus APs and then terminate to a Controller
Hello All,
We have a 105AP running the Code of an Instant AP. I have tried all possible ways to convert this AP to a Campus AP (CAP) to no avail.
It simply just comes up as an Instant AP.
I even set the Instant AP to factory default and still.
Even after setting it to factory default, I connected it to a Physical Port on the 620 Controller. It still came up as an Instant.
Can Instant APs be really converted to Caps?
Re: Instant APs cannot be converted to Campus APs and then terminate to a Controller
You have to go under Maintenence> Convert to point it to an active controller to convert.
Yep! Tried that over 5 times and still could not get it to convert to a CAP.
What version of code is on the controller?
6.0.1.0
Unfortunately, you need a minimum of ArubaOS 6.1 on the controller to convert the APS.
Do you think the Software Version on the 620 Controller could be the issue?
**bleep**! Oh well.
I always knew we might need to upgrade at sometime.
Is there a link or documentation where I can reference this?
We are trying to get it added as we speak.  Please see the thread right here:  http://community.arubanetworks.com/t5/Access-Points/Converting-IAP-105-to-an-AP-105/m-p/14594/highlight/true#M2054
Thanks Joseph.
Will try that out and keep you updated.
