Instant Mesh commands
Hi community,
Are there any commands to know the status of a mesh link? I have a mesh network, but when I run the commands "show ap mesh link" or "show ap mesh neighbours" I have no output:
Here you can see the mesh network in the Web UI:
Many thanks in advance!
Re: Instant Mesh commands
It looks like you named an SSID "Mesh Link", but you do not have any mesh links formed.
Colin Joseph
Aruba Customer Engineering
Hi Colin,
Yes it seems so. I have two SSIDs, "Santander CONSUMER" is only 2.4 GHz for users access and "Mesh Link" is only 5 GHz for the mesh and no users access, but it seems the APs are connected by a wired infrastructure. I will investigate.
