Instant Mesh with PoE
Dear Members,
Our customer would like to make Mesh with Instant APs with PoE. Is it possible, or do they have to use ac adapter instead?
Thank you for your help in advance.
Best regards,
Re: Instant Mesh with PoE
Mesh with IAP using the PoE works fine. Just search 'IAP Mesh' in the Community forum here, there's literally dozens of posts on how to do it.
Jerrod Howard
