Instant SSID does not disappear
Hi guys,
When I set up an IAP from scratch, the instant SSID appears, I connect and access the WebUI. When I create other SSIDs, the instant SSID keeps showing and broadcasting and does not disappear. I have read in the Instant user manual that after creating other SSID, the instant SSID should dissapear. In my case, it only disappears and stops broadcasting when I reboot the IAP, is this normal behaviour?
Julián
Re: Instant SSID does not disappear
It actually stops broadcasting when nobody is connected to it. If you create another SSID, the instant SSID will not be torn down until you disconnect from it...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi Colin,
You are right! I have just tested and the instant SSID disappeared. Thanks!
Best regards,
Julián
