Collegs, need your advice!
as i know virtual controller Aruba instant of IAP-93 didn's suport sum functions starting from 6.4.x.x-4.1.x.x releases:
Reintroducing IAP-92/93 in Aruba Instant 6.4.0.3-4.1.0.1 and future 6.4.x.x-4.1.x.x
releases
Support for IAP-92/93 is reintroduced in Instant 6.4.0.3-4.1.0.1 and will continue in future 6.4.x.x-4.1.x.x
releases. However, the following features are no longer available for IAP-92/93 in 6.4.x.x-4.1.x.x releases:
l AirGroup
l Internal RADIUS server for 802.1x authentication
l EAP Termination
l Authentication Survivability
l LLDP integration
The features listed above may be configured through Instant CLI/Web UI and AirWave Management Platform,
but will have no effect on IAP-92/93. In a cluster running Instant 6.4.x.x-4.1.x.x, only IAP-92/93 will have the
above limitations.
In order to conserve memory, IAP-92/93 is now restricted to a single active CLI session, either through a
console, SSH, or telnet. An error message "All CLI sessions are in use" is displayed if the user attempts to
open multiple sessions.
the question is: "will Internal RADIUS server for 802.1x authentication" works if it will be configured on IAP-103/IAP-205 as a virtual controller in the same claster with IAP-93?
