MVP
Integrated Antenna Specification
Hi Geys
I Need specifications for Aruba Integrated Antenna 93, 105 , 135
the details that  I need are the following
-- Polarization & Element Type ??
-- Bandwidth (Degrees) ??
--  VSWR ??
-- Max Input Power ??
I have search in google but send me to datasheet.
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
MVP
Re: Integrated Antenna Specification
Do these have what you're looking for:
http://www.arubanetworks.com/technology/datasheets/#access-points
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Aruba
Polarization, type and pattern is specified in the respective AP datasheets.
VSWR and max power of integrated antennas are not published (not visible or useful to AP users).
/Onno Harms, Aruba
/Onno
