Super Contributor II
Integration of Aruba with OPERA Property Management System
This may be not the exact board to ask this question here. but i ask it because it is related with Aruba OS configution..
Please advice Aruba controller can be integrated with OPERA Property Management System??? is it possible for the aruba controller to extract user name password system from opera which is used in captive portal.
This is going to be implemented in hotel
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
MVP
Re: Integration of Aruba with OPERA Property Management System
[ Edited ]
Hi
:smileywink:
As far as i aware - Opera billing system (found in most of the hotels) using COM-SERIAL connectivity - u must use 3rd party GW to the hotel guests vlan - Like a nomadix.
Here is an example diagram (i deployed a lot of hotel via this topology)
*As u can see the nomadix (Gateway for visitors/guests getting the needed information | billing information via serial cable directly from the hotel/hotels opera server)
hope it clearly you question.
have a lovely week. :smileyhappy:
me
MVP
[ Edited ]
Hello Kdisc98
Have you succesfully integrate clearpass guest  with OPERA?  i see this option which i think its related to that
If its is there any step by step manual somehwere on how to integrate it with this management system? it would be really helpful to us
I mean what do i need to do in the opera, and what do i need to do in the clearpass, but as far i see on the clearpass is the easiest part maybe?
Carlos
Alternetworks Corp
Nice Info NightShade1,
Asa, Please confirm, I also need to configure the same
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
