Intel AC 7260 Connectivity issues
Ref http://community.arubanetworks.com/t5/Wireless-Access/Intel-7260-VHT-disconnects/td-p/224363/page/3
I have many  HP zBook Laptops that have the Intel AC 7260, i have poured over the forums and I am just wondering if anyone has found a good solution to the drop out issue common to these cards?  When running a ping about eery 5-10 pings will jump to over 200ms. I am running the aruba 3600 with 105's. I have tried many different drivers and cannot find a solution that works. Thoughts are appreciated.
Re: Intel AC 7260 Connectivity issues
The AP-105s do not have a VHT component (802.11ac), so that might not fit your use case.
What version of ArubaOS and What version of the Intel 7260 AC  client?
Ok. I am currently running AC 7260 17.1.0.19 although i have tried the latest version as well with no improvment.  6.4.3.2 is my aruba os. I just did not know if there was a combination of items i could try to resolve this.
What other clients do you have that are working?  I personally are not aware of any 802.11n-specific issues with that Intel Client...
