Contributor I
Re: Intel Centrino 6205 and AP-225 headaches
3 SSID's
15 to 20 metres
(TNE-Wi-Fi-Coo) #show ap arm state ap-name NEI_COO_CLC2_AP
AP:NEI_COO_CLC2_AP MAC:44:48:c1:d8:20:80 Channel:11 EIRP:6 Max EIRP:21.5 Edge:disable
Client Density:0 Valid neighbors: 6 Relevant neighbors: 6 Rx Probe Reports: 19095
Moves(T/S):0/0 Sticky(T/S):0/0 Bandsteer(T/S):0/0 Loadbal(T/S):0/0
Neighbor Data
Name IP Address SNR (dB) Path Loss (dB) Channel/Pwr Neighbor Density Neighbors (R/T) Relevant
NEI_COO_CLC3_AP 172.25.136.99 28 76 1/9 0 5/5 Yes
NEI_COO_CLC1_AP 172.25.136.95 29 71 11/6 0 9/9 Yes
NEI_COO_CLC6_AP 172.25.136.106 38 62 6/9 0 7/7 Yes
NEI_COO_CLC4_AP 172.25.136.97 36 64 6/6 0 8/8 Yes
NEI_COO_CLC5_AP 172.25.136.105 34 66 1/9 0 7/7 Yes
NEI_COO_BG07_125_AP 172.25.136.54 2 102 11/9 0 6/6
Legend: R = Relevant, T = Total, Neighbor Density = (Overlap/Neighbor's Density/ Overlap to local density ratio/ Overlap to neighbor's density ratio)
AP:NEI_COO_CLC2_AP MAC:44:48:c1:d8:20:90 Channel:36 EIRP:18 Max EIRP:19 Edge:disable
Client Density:0 Valid neighbors: 5 Relevant neighbors: 5 Rx Probe Reports: 19079
Neighbor Data
NEI_COO_CLC1_AP 172.25.136.95 39 79 112/18 0 4/6 Yes
NEI_COO_CLC4_AP 172.25.136.97 33 80 149/18 0 6/6 Yes
NEI_COO_CLC5_AP 172.25.136.105 42 73 157/18 0 5/5 Yes
NEI_COO_CLC6_AP 172.25.136.106 40 111 60/18 0 3/3
NEI_COO_CLC3_AP 172.25.136.99 37 79 44/18 0 4/5 Yes
ARM a radio: 18 - 12
ARM g radio: 9 - 6
I don't think that density is bad, at all.  Do you have "Drop Broadcast and Multicast" enabled on all of your SSIDs?
Contributor I
After just having a look.... No I don't.
You should enable it on all of your Virtual APS.
Contributor I
Have done that now. Unfortunately these buildings are hours away from me so getting someone to test maybe difficult.
These are our oldest model of laptops and there are very few left in the fleet (including mine)
Mark down the time and date you made the change.  If you have Airwave, see if the Channel Utilization is going down for those APs over time.
Contributor I
Don't have airwave.
The dashboard on the controller GUI has the channel utilization.  Change it so it is only showing 802.11a (5ghz) band.  See how many APs are in the 40 to 50% range.  Do the same thing on the 802.11b/g (2.4ghz) band.
Contributor I
At the site I have been using for testing, All of the new AP's are at 35% to 52% in the 2.4 band.
Contributor I
Same at one of the other 4 new sites and there is actually only 1 client connected at the moment.
