Occasional Contributor I
Intel(R) Centrino(R) Advanced-N 6235 not connecting to 103 AP
Intel(R) Centrino(R) Advanced-N 6235 adapter came on my Dell Ltittude E6440. I'm trying to connect to aruba 103 AP with no luck the encryption method used is WPA 2 Personal
Any idea why? (I have updated the wifi driver to the latest 15.4.1.1)
Thank you
Re: Intel(R) Centrino(R) Advanced-N 6235 not connecting to 103 AP
Do you mean WPA2?
Yes, sorry
1.  Try to associate the client to an AP
2.  When that is done, on the commandline of the controller, type "show ap remote debug mgmt-frames ap-name <name of ap>" and paste the output into here.
3.  Can you associate other clients to the AP103?
What cleint, could you please be more descriptive, do you mean the web UI?
Try to associate the laptop with the wireless adapter to the AP.
Did you upgrade your wireless driver on the Dell? If not please do so
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
I Did, nothing has changed
