Interface Description
Wanted to check  the restrictions on interface description . It appears to be 30 characters.   Also are there any restrictions on kind of characters used?
Re: Interface Description
there are no restrictions on kind of characters on Mobility Access Switches for interface description.
Retired Employee
The length of the description has a limit of 32 characters
1. 33 characters
(ArubaS3500-24P)(gigabitethernet "0/0/1") #description "123456789012345678901234567890123"
% Invalid input detected at '^' marker.
2. 32 characters
(ArubaS3500-24P)(gigabitethernet "0/0/1") #description "12345678901234567890123456789012"
(ArubaS3500-24P)(config) #show interface gigabitethernet 0/0/1
GE0/0/1 is administratively Up, Link is Up, Line protocol is Up
Hardware is Gigabit Ethernet, Interface is 12345678901234567890123456789012, Address is 00:0b:86:6b:0b:83
HT
