Interface errors
  • 1.  Interface errors
    Posted Jan 11, 2013 11:13 AM
    the uplink from our 3400 has been getting errors to the tune of ~1200 an hour. I would think this would be a cabling issue, but I would expect the errors to fluctuate more and give types of errors (CRC, Giant ect).  Anyone have any ideas what could cause this or where I should look?
    Last clearing of "show interface" counters 4 day 14 hr 15 min 15 sec
    link status last changed 4 day 14 hr 12 min 18 sec
    33106926 packets input, 8426532987 bytes
    Received 3197391 broadcasts, 0 runts, 0 giants, 0 throttles
    120364 input error bytes, 0 CRC, 0 frame
    We run multicast on the LAN but dont have any multicast settings on the controller configured.  That was my only other idea.  Thanks.
    #3400
  • 2.  RE: Interface errors
    Posted Jan 11, 2013 11:19 AM
    Check the following :
    -  Gbics , Cabling
    - Speed / Duplex settings
    - Do you have configured as a port-channels ?
    Are you experiencing issues with users or APs rebooting / bootstrapping ?
  • 3.  RE: Interface errors
    Posted Jan 11, 2013 11:31 AM
    It is using the copper port. (Could configure another port and have someone move the cable over).
    Both sides are configured auto auto negotiating to 1000 full (as they should)
    No port channel.
    No issues that I have been made aware of.  Layer 1 seems the most likely to me too (just wish it wasn's as this is a remote site).
  • 4.  RE: Interface errors
    Posted Jan 11, 2013 11:35 AM
    Are you also seeing errors on the uplink interfaces ?
  • 5.  RE: Interface errors
    Posted Jan 11, 2013 11:37 AM
    Uplink interface is clean.
     MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
         reliability 255/255, txload 1/255, rxload 1/255
      Encapsulation ARPA, loopback not set
      Keepalive set (10 sec)
      Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
      input flow-control is off, output flow-control is unsupported
      ARP type: ARPA, ARP Timeout 04:00:00
      Last input 00:00:00, output 00:00:00, output hang never
      Last clearing of "show interface" counters 3w1d
      Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
      Queueing strategy: fifo
      Output queue: 0/40 (size/max)
      5 minute input rate 121000 bits/sec, 65 packets/sec
      5 minute output rate 176000 bits/sec, 79 packets/sec
         98265641 packets input, 20353659260 bytes, 0 no buffer
         Received 1141185 broadcasts (1064312 multicasts)
         0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
         0 watchdog, 1064312 multicast, 0 pause input
         0 input packets with dribble condition detected
         123227648 packets output, 34328504737 bytes, 0 underruns
         0 output errors, 0 collisions, 0 interface resets
         0 babbles, 0 late collision, 0 deferred
         0 lost carrier, 0 no carrier, 0 PAUSE output
         0 output buffer failures, 0 output buffers swapped out
  • 6.  RE: Interface errors
    Posted Jan 11, 2013 11:39 AM
    What code are you running ?
  • 7.  RE: Interface errors
    Posted Jan 11, 2013 11:43 AM
    You could try using another GBIC or reseating , that has happened to me a couple of times.
  • 8.  RE: Interface errors
    Posted Jan 11, 2013 11:46 AM
    Yeah, just easier to troubleshoot missconfigurations remotely than it is physical. Thanks.  Will report my findings after changing out physical interfaces.
  • 9.  RE: Interface errors
    Posted Jan 12, 2013 04:05 AM
    Try manually set your speed and duplex mode both on Controller and the switches port.
    Goodluck!
  • 10.  RE: Interface errors
    Posted Jan 12, 2013 06:49 AM
    Javin.Craig,
    Is there a VLAN on the switch side of the trunk that is not configured on the Controller side of the trunk, or is it even a trunk?
    Try matching VLANs on both sides and see if it remedies the issue.
  • 11.  RE: Interface errors
    Posted Jan 11, 2013 11:45 AM
    6.2.0.1
  • 12.  RE: Interface errors
    Posted Aug 01, 2018 01:27 AM
    Clear the interface counter and start with changing the fiber patch between the 2 switches. If that does not help then replace the GBICs and see what happens.
