Interface management msr2000
Hi all
I've setup eth0 as trunk and VLAN 212 native also as a management interface. I ping from VLAN 211 unreachable, What about false in my config?
I hope can help me
Re: Interface management msr2000
You could post your config, otherwise I would assume either the management IP is not set correctly or the switch uplink isn't correct.
Jerrod Howard
Thank's jerrod
Here's my config, by the way the switch I used catalyst.
I don't see a default gateway, so are you trying to access the AP from the same subnet? Is this an old or a new MSR? Have you connected your laptop directly to it through a power injector and then can you see 212? If you change the port to access on 212, can you then see it?
Here is what my lab setup looks like, SSID carries on 150, management is on 100.
interface gigabit-ethernet 0
mode gateway
switchport trunk allowed-vlan 100,150
switchport trunk native vlan 100
interface loopback 0
ip address from-mac
interface vlan 1
mtu 1500
interface vlan 100
ip address
mtu 1500
ip route
Jerrod Howard
