Hi there,
I've been working for a few months on improving a deployment I inherited. We recently used Ekahau Site Survey to figure out where to move the APs, and are seeing generally good performance except when this issue occurs.
The issue: Client has good RSSI and transmit rate and can pass traffic normally. Suddenly traffic stops flowing. The transmit rate drops to 14 and the MCS index to 0, while RSSI stays at the same (acceptable level.) If you wait 30-60 seconds or turn wifi off and back on, the connection is restored. It seems to be either localized to an AP, or a single client. I've observed it occuring 1-3 times during a work day.
Current environment:
* 10000 sq feet, open floorplan concrete office building
* AC ducting and fluorescent lighting fixtures everywhere
* 9 AP205's (9 radios on 5 @ 40MHz, 4 on 2.4 @ 20MHz)
* Mode aware ARM enabled
* 2.4ghz: max 15 min 12 - 5ghz: max 15 min 12
* short preamble
* non wifi interference immunity 3
* client match enabled
* band steering preferred on both bands
* 2 SSIDs
* drop broadcast and unknown multicast
* convert broadcast arp requests into unicast
The performance is good when it works but they're threatening to replace it with another system if we can't figure this last issue out. Any ideas?
Thanks!
