Regular Contributor I
Internal System error - should I be concerned?
Keep gettitng this error everywhere:
Dec 23 13:08:19 2015 XXXXXXXXX sapd[1731]: <326268> <ERRS> |AP XXXXXXX@XXXXXXX sapd| An internal system error has occurred at file channel.c function ch_check line 1382 error default_ch_cnt 0 .
I have removed the IPs and AP names with X's.
Anyone seen this?  It all seems functional, but cant help thinking not optimal?
Re: Internal System error - should I be concerned?
You need to open a TAC case.  How servere it is depends on the message and the version of ArubaOS.
Opening case!  Will update with outcome later :)
Anyone looking at this thread I am using:
ArubaOS (MODEL: Aruba650), Version 6.4.2.5
Website: http://www.arubanetworks.com
Copyright (c) 2002-2015, Aruba Networks, Inc.
Compiled on 2015-02-24 at 22:02:57 PST (build 48774) by p4build
Relates to channel use in particular regulatory domains.  We have a bunch of WIFI networks all controller from a single master pair that applies appropriate regulatory domains depending on the country etc.
apparently additional channels need to be assigned per TAC advice
...although I can help thinking that these channels are disabled to comply with the regulatory domain?
ask TAC and get back to us...
:) OK!
