I have a issue with the internal db.
We have some have on some ssid´s with mac auth + 802.1 X.
The internal db is loose again and again one entry. I have write it again in the db a few times. But after a random time the entry isn´t in the db.
Yes I apply the edit of the db and save configuration too.
Anyone have this problem bevor or have any ideas?
Cheers
