@AirAO wrote:
Hi!
Some input here - check logon-role (see image 1) or 802.1x authentication Default Role - if You configured a 802.1x SSID so Captive Portal Profile should be set to "Not Assigned" (if I understood your problem right)
Or You should update ArubaOS to 6.2.1.6 where issue with CaptivePortal and iOS7 devices are solved (see image 2)
No actually when i connect to SSID. In iOS devices, captive portal page pops up prompting to enter username and password for provisioning.
My problem is when i connect to dot1x ssid, captive portal page pops up and i can see login form with instructions . At that time iOS devices loses its wifi connectivity. Then i have cancel the pop up (captive portal page ) and i have to open browser manually to provision and onboard the devcie
