Is ArubaOS8 Lab in AWS possible?
I need to build a lab for learning Aruba OS 8 for the exam, I only have an AMD machine which won't install the OS.
Can I run these in AWS, has anybody run them in AWS or something similar?
Re: Is ArubaOS8 Lab in AWS possible?
AOS8 is not supported on AWS or Azure.
Is supported on vmware and KVM and Hyper-v (on certain version I think).
Cheers
James
