Is FTRJ8519P1BNL-PT comaptible with M3 controller?
Hi All,
I would like to confirm if FTRJ8519P1BNL-PT is comaptible with M3 controller or not. I checked in Aruba Interoperability list and I do not see it listed.
Below is the output about the SFP being used;
# show interface gigabitethernet 0/0 transceiver
Module is SFP
Manufacturer : FINISAR CORP.
Part Number : FTRJ8519P1BNL-PT, rev: A
S/N : P9H17A4
Date Code : 060501 Lot:
Optional Signals : LOS Tx Disable
Supported Modes : 1000Base-SX, LC Connector
Thanks in advance.
Karthikeyan Mookkandi
Re: Is FTRJ8519P1BNL-PT comaptible with M3 controller?
If it is not on the list or in the M3 installation guide, it is not supported.  It might work, though.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thank you!
