Is possible to limit maximum users number and bandwidth in a WLC 7030?
I want to limit maximum number of users per SSID and bandwitdh per user. Is possible to do this, like is done with Virtual Controller?
Re: Is possible to limit maximum users number and bandwidth in a WLC 7030?
You would limit users per radio using the Max Associations parameter in the SSID profile http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/VirtualAPs/SSID_Profiles.htm  By default this is 64.
Clientmatch is enabled by default and will start load balancing devices at the "cm-lb-client-thresh"  (clientmatch load balancing) parameter in the ARM profile:    http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/ARM/ARM_Profiles.htm%3FTocPath%3DAdaptive%20Radio%20Management%7C_____4
Client Match        Enabled
Client Match report interval (sec)                                           30
Allows Client Match to automatically clear unsteerable clients after ageout  Enabled
Client Match Unsteerable Client Ageout Interval                              2 Days 0 Hours
Client Match Band Steer G Band Max Signal (-dBm)                             45
Client Match Band Steer A Band Min Signal (-dBm)                             75
Client Match Sticky Client Check Interval (sec)                              3
Client Match Sticky client check SNR (dB)                                    18
Client Match SNR threshold(dB)                                               5
Client Match Sticky Min Signal                                               65
Client Match Restriction timeout (sec)                                       10
Client Match Load Balancing threshold (%)                                    20
Client Match IOS Steer Backoff interval (sec)                                300
Client Match VBR Stale Entry Age (sec)                                       120
Client Match Max steer failures                                              2
Client Match Load Balancing client threshold                                 30
Client Match Load Balancing SNR threshold (dB)                               30
Client Match Load Balancing signal delta bound (dB)                          5
Client Match 11v BSS Transition Management                                   Enabled
 The bandwidth that a user is restricted is configured in the user role.
You can limit users per radio per ssid in the ssid profile in the advanced mode (see the screen-shot)
the bandwidht can be limited in the role  (see the screen-shot)
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
