Is there a CLI command to show air monitor details similar to what is in the GUI.
When I do a "show ap database-summary" it shows that I have multiple are monitors.
From the GUI I can easily click on "All Air Monitors to see them"
Is there a CLI command to chow the same basic AM information (eg. Name, Ap Group, Status, IP,  etc...)  ?
Re: Is there a CLI command to show air monitor details similar to what is in the GUI.
you cna likely do a 'show ap database | include AM' (not it's case sensitive, but whatever is after the include would be a search string for any string in the line output.
Jerrod Howard
Hi.
Yeah I tried that and it did not show them.
I have 32 AM's on a local controller and I tried to show them from both the master and the local and I can't find a command that does it from the CLI.
The easiest way I can find it to go into the gui but if the gui can differenciate them I assume there has to be a way in the CLI to do the same.
Dave
"show ap active | include AM"
That worked.
Thanks Joseph.
