Is there a way to check what a user downloaded after they are off the system.
I recently balcklisted a user from our wirless system.  They were off-line when I did this and was not able to see what the user was doing.  I have been asked if I could show what the user was doing.  Is there a way to find what sites the user was at after the fact?
Thanks!
Re: Is there a way to check what a user downloaded after they are off the system.
You cannot.  That information is not stored anywhere...
