Is there a way to control the number of mDNS queries from controller ?
I have a customer with 2k clients in a single vlan, I found a lot of mDNS queries are generated from their controller. I was told there might be some keepalive mechanisms like, for example, a controller sends queries for all mDNS caches it has. Then I made a search in the CLI reference guide, and I found this command below "airgroup query interval ". I am confused by its explanation, does it mean to change the query interval for CPPM server or mDNS queries. Since it's a production environment that is going to be modified, I have to be very careful about any confusion in mind. Anyone can help to clarify or advise:
1. Is this command below controls CPPM query or mDNS query?
2. If it is a CPPM, any idea how to reduce the mDNS generated by a controller?
Re: Is there a way to control the number of mDNS queries from controller ?
The question is, is the network currently using Airgroup for device discovery at all? Having 2k clients in a network is a heavy lift by itself.
Yes, they are using Airgroup, and they complain about occasionally loss of connection with some production servers used for file storage every day.
By digging into a packet capture, I noticed there are too many multicast packets including mDNS and IPv6.  I made some ACLs in the access switches to screen out IPv6 packets which are not useful to their services. It seems to work out a little bit, so I wonder whether there is a further way to reduce mDNS cast in the network, even though I can't screen them all as Bonjour is one of their services.
I noticed there is a command in CLI reference which seems to indicate Airgroup is able adjust the rate of mDNS it sends out, so I think it might help if it works as I assumed. Just for discretion before I put it into production configuration
BTW, I have advised them to think about segment users by more vlans, however, this customer is lack of motivation to do so as the environment is already in production
"Zach_Z wrote:
Yes, they are using Airgroup, and they complain about occasionally loss of connection with some production servers used for file storage every day."
Are you saying that they use file storage for Airgroup or are you guessing that mdns traffic is causing your file server problem?  Is the problem occurring for wired and wireless clients, as well?
I guess the m/bcast including mDNS traffic occassionaly interrupts their connection with file storage. Most affected are Wireless clients.
