SBU
Is there a way to convert cisco configs to aruba configs?
Hello - I am new to the aruba world, we are replacing a few cisco switches to aruba, and was wondering if there is a way to convert the cisco configs to aruba configs?
thanks in advance.
MVP
Re: Is there a way to convert cisco configs to aruba configs?
Not that I know of. You should check out www.ase.arubanetworks.com
Sean Rynearson
Aruba
Russo21,
Sean is correct that we do not have a converter tool but the Aruba Solutions Exchange is a good starting point. Here is the correct URL:
https://ase.arubanetworks.com/
Best regards,
Madani
Trusted Contributor I
Sidenote: Had no idea. ASE existed...  It's pretty sweet!  Hope to see it develop more.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
