Is there a way to only broadcast N with AP-105's connected to a 620 controller?
I would like to set up my wireless network with my 620 controllers, and AP-105's, but only offer N wireless. Is there a way this can be done from the controller?
Aruba
Re: Is there a way to only broadcast N with AP-105's connected to a 620 controller?
Yes, this can be done by changing the ht-ssid-profile.  If you want it to only happen to certain APs and not others, you'll need to create a new ssid profile and apply the new ht-ssid-profile, and then add to a VAP and then ap-group.
wlan ht-ssid-profile <name>
no legacy-stations
If you want to deny 802.11b stations completely, just remove the 1,2,5 & 11 rates from the ssids.
Alternatively you may want to consider having a traffic-management-profile within the ap-group with a shaping policy of 'preferred-access'.  This will give preference to HT stations and prevent legacy clients consuming airtime.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
