Is there any tool for request for proposal?
I am interested in a tool for request for proposal using aruba products for a wireless system. Can it be possible?
Re: Is there any tool for request for proposal?
If you are a partner, those resources exist on the partner website.  Are you a partner?
Colin Joseph
Aruba Customer Engineering
No, I am not Arubas parner We have applied for that.
HI
Iam having same need , iam partner could you refer to me where can i find such docment for aruba product
Eslam Gamal
Eslam, as a partner, the resources you need are on the partner portal. Your channel account manager can help make sure you have access there.
Charlie Clemmer
