Frequent Contributor I
Is there anything I have to worry about in turning on Control Plane Security?
 We want to bridge an AP and it seems that CPS is required to be turned on for this. I am worried if there are bad consequences on turning this on. Is there anything I should do first before doing this?
Thanks.
Re: Is there anything I have to worry about in turning on Control Plane Security?
Enabling it in a production environment will cause 5-10 minutes of downtime depending on the size of your environment.
You also need to be sure that you add UDP 4500 between your APs and controllers.
Tim Cappalli | Aruba Security
Trusted Contributor I
turning on auto cert provisioning, certainly at first seems wise also, though i believe it is the default.
did it work out for you fine?
